Hi
Just fitted the master cylinder(new) and slave cylinder(new) to my MX5 clubman build. Thrust bearing and fork all seemed ok when I attached the gearbox to the engine. Clutch pedal pressure is pretty hard - harder than I expected compared to something like a Corolla. How hard is the standard pedal ? Is it fairly strong or could there be something I've overlooked. The clutch looks stock OEM for a 2002 MX5. I know the pedal ratio is different to standard ( see link photos ). Could it be the pressure plate ? Clutch has done about 80,000 Kms.
http://s637.photobucket.com/albums/uu94 ... 305980.jpg
http://s637.photobucket.com/albums/uu94 ... CN1085.jpg
- Vehicle: ND - 1.5 GT
- NitroDann
Re: Clutch pedal pressure
Could be the thrust bearing is tight, or the fork is not installed correctly. Its a pretty soft clutch stock.
- tobias
That clutch pedal looks like it has. Short through maybe that has something to do with it?
