Good mechanic Northern Suburbs
Pokmx5
Postby Pokmx5 » Sun Sep 18, 2011 12:07 pm
Hey guys,
Just picked up my mx5 the other day and it needs a good service and while im doing that i want to get the timing belt and all the other belts changed also. There is a small oil leak from the back of the rocker cover and a small water leak somewhere also. Any good mechanics that people use in the northern suburbs?
geofiz
Re: Good mechanic Northern Suburbs
Postby geofiz » Sun Sep 18, 2011 12:39 pm
northern suburbs of Darwin?
It may be helpful to add some clues about your location. :D
NB8A - mostly stock for now
Postby Mr Morlock » Sun Sep 18, 2011 6:22 pm
I guess we are talking about Melb. The MX5 Factory ( Ringwood) are competent but underline get some quotes. If you do the timing belt then water pump is virtually a given but cost is going to be somewhere in the region of $800. Some reckon it is better bet to use OEM belt and pump and some of the repairers only use oem.
Pokmx5
Postby Pokmx5 » Sun Sep 18, 2011 7:22 pm
Im in melbourne.. sorry i should of mentioned that.
Mx5 factory, hmm i like the sound of that. I was looking for more local around the Fairfield region.
de Bounce
Postby de Bounce » Mon Sep 19, 2011 12:15 pm
Beg's the question - what do you want done?
Specialist in a particular field or a general mechanic for maintenance?
Motorkhana Video
Pamex
Postby Pamex » Mon Sep 19, 2011 1:27 pm
Not northern suburbs, but you should really consider Allmaz in Clayton. Good, solid work that they stand by and cheap.
Matty
Postby Matty » Mon Sep 19, 2011 1:37 pm
Much as we love our cars and only want the best, they're dead-easy to work on and parts are common (whole 323 and Ford Laser range from the same era) and cheap. A timing belt, water pump and rocker cover gasket will be a cakewalk for any mechanic.
Pokmx5
Postby Pokmx5 » Mon Sep 19, 2011 2:58 pm
well i took it to my local mechanic ive used for years. So far his fixed the water leak and changed the rocker cover gasket. All for 300 including labor and parts :D. He was happy i brought him a easy tow ork on car rather then my usual Audi's lol.
Next thing that needs to be done is Timing belt and all related belts :D
Postby NitroDann » Mon Sep 19, 2011 3:01 pm
What matty said.
I walked 2 absolute novices (never picked up a spanner types) through this exact work in an afternoon and hardly lifted a spanner myself. they were fine, they are that easy.
Postby manga_blue » Mon Sep 19, 2011 3:25 pm
x3 with Matty and Dann, but refitting the crankshaft pulley after a timing belt change is something that requires special care and they should be made aware of that.
Maranello Pursang Motors, Coburg, is worth asking. Proprietor Bruno is the chief scrutineer for the Alfa club and has dabbled successfully in MX5s with a few of us.
Pamex
Postby Pamex » Mon Sep 19, 2011 3:39 pm
Ooh, definitely give Maranello a go.
Even if you just want to go and gawk at the motoring memorabilia that covers their walls and floors...
They're good guys.
Pokmx5
Postby Pokmx5 » Mon Sep 19, 2011 6:17 pm
wow it runs perfect now :D all thats needed is the timing belts and im set :D new tyres and im all good :D.
im loving the mx5 more and more :D
Postby 93_Clubman » Wed Sep 21, 2011 12:21 pm
Pokmx5 wrote:Any good mechanics that people use in the northern suburbs?
Pokmx5 wrote:I was looking for more local around the Fairfield region.
Fredbareoz on here is the Service Manager at Kirwan's in Preston.
Users browsing this forum: Bing [Bot] and 6 guests
