Few little problems.
de Bounce
Re: Few little problems.
Postby de Bounce » Thu Sep 08, 2011 10:58 am
Fuel smell in the cab would indicate a hose has perished somewhere around the tank.
Pull the boot lining and hose guard in the boot (filler/passenger side) and check for leaks/cracks
Also have a look at the top of the tank where the fuel pump lines are.
There is a manual available here which might help
Motorkhana Video
de Bounce
Postby de Bounce » Thu Sep 08, 2011 11:00 am
Also welcome to the forum and obsession :beer: :D
Quick introduction of your MX5 with photo's is good :NA6:
Adding the area you live in your profile is also beneficial :mrgreen:
Motorkhana Video
Postby 93_Clubman » Thu Sep 08, 2011 11:54 am
Sounds like the following, except for direction of corners:
viewtopic.php?f=29&t=45597&p=575578#p575578
Postby manga_blue » Sun Sep 11, 2011 9:39 pm
Mazda's assembly line process was based on building the entire car around the fuel tank. :(
Postby Mr Morlock » Mon Sep 12, 2011 12:27 pm
how much things cost is a very easy exercise- just visit or call Mazda, or Bursons, or sponsors or look on line etc. It really might be better getting a further diagnosis - petrol will certainly go stale and it makes sense that there could be blockages in the "system" including perhaps injectors? Smell of petrol certainly flags a risk. I think Manga is suggesting tank removal and what next is a stretch unless one has the knowledge.
Postby manga_blue » Mon Sep 12, 2011 12:51 pm
Manga is NOT suggesting tank removal. Tank removal starts with dismantling most of your car.
Postby Mr Morlock » Mon Sep 12, 2011 1:22 pm
yes not well phrased in my sentence- I certainly was not suggesting Manga was promoting tank removal. I do think caution is required.
taminga16
Postby taminga16 » Mon Sep 12, 2011 1:35 pm
Hi,
It may be that the tank has water in it caused by condensation and just sitting around with old fuel in it, add a cup full of Metho to the next couple of tanks of fuel ( the metho is Hygroscopic and will absorb any water and then burn off in normal running) then use a PULP with a cleaning agent, and keep an eye on the stuff that you have done already as you may get more residue.
Good luck.
Greg.
P.S. Dont forget to update your profile, help may be closer than you think.
pcmx5
Postby pcmx5 » Mon Sep 12, 2011 1:48 pm
I had a high flow pump fitted(aftermarket) for around $280 from memory, pump was only $185 i think.
Peter.
Postby 93_Clubman » Mon Sep 12, 2011 2:54 pm
brown_86 wrote:any idea how much a new fuel pump is?
Some on ebay under MX5 for under $100.
Postby 93_Clubman » Fri Sep 16, 2011 6:37 pm
brown_86 wrote:So, i got a new pump, but where can i get the right filter? i've been to mazda but they dont make em any more or some thing,
http://www.autoperformanceengineering.c ... mazda_apps
http://www.autoperformanceengineering.c ... /kits.html
