Engine build Rods Pistons
Novice1
Postby Novice1 » Wed Sep 07, 2011 6:10 pm
I am going to build up my engine bottom end. Looking for pistons 9:1 compression and H beam forged rods. I have sussed out the other costs of engine rebuild. Just rods and pistons to sort out.
Prices on pistons rods so far.
Pistons:
http://www.shop-cppistons.com/categories/mazda/ $280 each or $1120 plus shipping, taxes.
Mx5mania.com super tech pistons $650
Rods:
Flyinmiata.com carillo h beam rods $1230 plus shipping taxes
Mx5mania.com carillo h beam rods $1550
Mania currently have a special on carillo h beam rods and super tech pistons for $1950
Anyone with any other ideas, bring em on.
bigdog
King of the kennel
Re: Engine build Rods Pistons
Postby bigdog » Wed Sep 07, 2011 6:52 pm
I'm running Eagle rods and Wiseco pistons - bought the lot for under $1500 in the US. Shop around and you'll find some good deals. Both are great brands with really good reputations.
project.r.racing
Postby project.r.racing » Wed Sep 07, 2011 7:16 pm
lots of piston+rod combos under $1000 from the USA. search "miata piston."
Novice1
Postby Novice1 » Wed Sep 07, 2011 7:43 pm
Forgot..duh. My car is TURBO 172 kw atw........
Cheers novice
Novice1
Postby Novice1 » Wed Sep 07, 2011 8:36 pm
Davex3 wrote:How much are you shooting for?
If your shooting for about 300 - 350rwhp supertech rods and pistons are proven and cheap. Should go for a 1mm (84mm from 83mm standard, will work with oem headgasket) overbore also.
http://949racing.com/forged-connecting-rods-miata.aspx
http://949racing.com/supertech-pistons-miata.aspx
Or if you have money to burn and or shooting for big power go with carrilo h beams and wiseco pistons.
http://www.flyinmiata.com/index.php?deptid=4530&parentid=0&stocknumber=04-66000
http://www.flyinmiata.com/index.php?deptid=4530&parentid=0&stocknumber=04-69110%20%201990-93
Not really shooting for a particular figure Dave. I believe the Garrett t28 is good for 300hp however.
Just trying to keep the car safe with the current power output.
Thanks for the links.
Cheers novice1
Also i'm sure your aware to use arp everything. :mrgreen:
Novice1
Postby Novice1 » Wed Sep 07, 2011 8:57 pm
949racing rods for $309 out of stock till next February.
Novice1
zossy1
Postby zossy1 » Wed Sep 07, 2011 10:03 pm
You will reach the limits of your diff and gearbox before you reach the limits of the Supertech pistons or 949 Racing Rods.
M-Tuned also sells good rods for a cheap price. The same rods can also be purchased from verious eBay sellers for even less, but when buying from M-Tuned you get a more closely matched set in terms of weight (at least if you believe what M-Tuned say).
Novice1
Postby Novice1 » Wed Sep 07, 2011 10:15 pm
zossy1 wrote:You will reach the limits of your diff and gearbox before you reach the limits of the Supertech pistons or 949 Racing Rods.
M-tuned rods from K-tuned are out of stock till feb 12
cheers novice1
Postby NitroDann » Wed Sep 07, 2011 10:46 pm
Im sure ron youve noticed that the K Tuned, M Tuned and the cheap FM rods are all the same yeah?
Postby NitroDann » Wed Sep 07, 2011 11:00 pm
Lol, I dont know why youd go to carillos what the M Tuned rods are well well proven, savington uses M Tuned/Supertech in all his builds, and runs 400rwhp in his track car. Has done for years.
Novice1
Postby Novice1 » Wed Sep 07, 2011 11:21 pm
NitroDann wrote:Lol, I dont know why youd go to carillos what the M Tuned rods are well well proven, savington uses M Tuned/Supertech in all his builds, and runs 400rwhp in his track car. Has done for years.
If the m-tuned were available I would be laughing. Unfortunately I am not prepared to wait till feb 2012 for them to be in stock.
Cheers novice1
coop44
Postby coop44 » Thu Sep 08, 2011 3:47 am
try pistons for the automatic cars, they generally run 9 to 1 in the 1.6 cars, not sure about the 1.8 though. The stock pistons/rods are sufficent if you are not trying for obscene amounts of power. After all, they started out in a turbocharged application didn't they? I can source a set with rings over here in the U.S. for a little over a hundred bucks.
Novice1
Postby Novice1 » Thu Sep 08, 2011 10:28 am
cheers novice1
Car as torsen diff, built up clutch and strengthened gearbox.
Cheers novice1
Novice1
Postby Novice1 » Thu Sep 08, 2011 10:35 am
Can someone check the website for k- tuned, m- tuned or fm rods as to their availability.
My desktop and laptop don,t say they are available, my iPad says they are unavailable.
Going with wiseco pistons.
Cheers novice1
deviant
Postby deviant » Thu Sep 08, 2011 10:49 am
Strengthened gearbox....this interest me...what has been done?
Users browsing this forum: Bing [Bot] and 3 guests
