What to do or not do about running in clutch ???
criss
Postby criss » Thu Sep 01, 2011 3:17 pm
will put on a new clutch and flywheel on sat, and decided to have a bit of driving after that( haven't drive for 3 weeks) :frown:
i heard that the running in is important for the first 1500km??? is it true?
if so, what should i do to run it in and is there anything i shouldn't do during the period???
cheers
criss
Re: What to do or not do about running in clutch ???
Postby NitroDann » Thu Sep 01, 2011 3:23 pm
Ive never 'run in' a clutch. Engines of course, brakes every time, clutch... Never heard of it.
criss
Postby criss » Thu Sep 01, 2011 3:24 pm
dann cus you dun use clutch at all :mrgreen:
Dweezle
Postby Dweezle » Thu Sep 01, 2011 3:35 pm
When we installed the xtreme HD clutch, Xtreme just told us not to do any hard launches, or ride the clutch for about 1000ks.
No idea what could happen if anything but decided to take there advice and so far no issues.
Sent from my GT-P1000 using Tapatalk
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
PaulF
Postby PaulF » Thu Sep 01, 2011 3:53 pm
criss wrote:dann cus you dun use clutch at all :mrgreen:
Of course he uses it. He kicks it frequently. :wink:
criss
Postby criss » Thu Sep 01, 2011 4:12 pm
save the clutch on rolling start drag, kick the clutch hard when drift :P
criss
Postby criss » Thu Sep 01, 2011 4:15 pm
Dweezle wrote:When we installed the xtreme HD clutch, Xtreme just told us not to do any hard launches, or ride the clutch for about 1000ks.
what you mean by "ride the clutch'??
Postby NitroDann » Thu Sep 01, 2011 4:28 pm
It means dont slip it excessively.
criss
Postby criss » Thu Sep 01, 2011 4:40 pm
NitroDann wrote:It means dont slip it excessively.
got it =], thx dann
helpful as always
Russellb
RIP Nov 2014
Postby Russellb » Thu Sep 01, 2011 7:12 pm
Big thing is to recheck and adjust the free play after about 1000KM of driving.
as the clutch fricton plate wears in it MAY require adjustment.
it is more an ARSE covering thing for mechanics than anything else
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Postby Mr Morlock » Thu Sep 01, 2011 7:49 pm
Running in a clutch is not necessary. Abusing clutches such as riding a clutch - example driving with pressure on the clutch pedal is a good way to shorten its life.
criss
Postby criss » Fri Sep 02, 2011 7:00 pm
Thanks for advice guys :D
will put the clutch in tomorrow, will try to be more carful on the pedel fot sure
Users browsing this forum: Bing [Bot] and 6 guests
