Why dont you just find out if yours is a 97 or a 99?
Rebuild kit
- NitroDann
Re: Rebuild kit
- NitroDann
Re: Rebuild kit
Theres no such thing as a 98 model mx5.
If its an na, its a 97, if its an nb, its a 99. Mazda never made a 98 build.
- Bauer
Re: Rebuild kit
My thoughts - which Im happy to be corrected for - is that the USA Miata is usually a year behind Aus MX5
So your 98 MX5 is likely to be the 99 model they talk about.
cheers
Stu
Stu
- Vehicle: Non MX-5
Re: Rebuild kit
yup 98 in aus = 99 in usa
- NitroDann
Re: Rebuild kit
Its not that we got them early. There isnt a single 98 mx5 on the planet, they ran the 97 na half way into 98 and released the 99 nb half way through 98.
Re: Rebuild kit
while I'm sure your correct dann, someone looking at the build plate on the car will see 98 if there car was early build nb.
Its like aus delivered 89 na 6 s. theoretically doesn't exist, but some of the early 90 model cars were built in 89 but complianced in 90.
Re: Rebuild kit
To OP, you'll need the '99-'00 kit as there are head differences, & intake manifolds are not interchangeable without welding, so intake manifold gasket also won't interchange.
My old NA6, number 238, was built Oct '89, complianced Nov '89, & purchased in Nov '89. My understanding is there are NB8As in Australia that were both built & complianced in '98.
sailaholic wrote:Its like aus delivered 89 na 6 s. theoretically doesn't exist, but some of the early 90 model cars were built in 89 but complianced in 90.
Re: Rebuild kit
Intersting to know
Re: Rebuild kit
Similarly, my Aust delivered NA8 is built Sep '93, complianced Oct '93, rego'd Nov '93, & purchased in Dec '93 - it's a '93 model in Australia, not a '94 model, although in the US it would be called a '94 model. Same with the NB8A.
