Bad Engine Hesitation - Help Required Please
Re: Bad Engine Hesitation - Help Required Please
Postby NitroDann » Sat Aug 20, 2011 8:03 pm
First guess, take the leads off and check in the hole where the leads go for 10cm of water. Ive done this one before. :mrgreen:
Postby hks_kansei » Sat Aug 20, 2011 8:14 pm
the NB is VERY pedantic about water in the plugs.
I got a tiny bit in my plug wells the other day and it started running on 3 cylinders.
so step one, as Dan said, remove the plug leads and check they are dry.
as for the fuel, it's been in the tank for nearly 8 months? it would most certainly have gone stale.
If it's running I'd go for a long drive to basically use up the old fuel, then once that's mostly gone give it a fill with nice fresh fuel (whatever you normally use)
maybe try a bottle of octane booster to try and bring the fuel back a bit? won't be ideal, but should be better than nothing.
slimx
Postby slimx » Sun Aug 28, 2011 9:08 am
wouldnt burning that sh*t fuel , sh*t all over your spark plugs?
Drain the tank, use any kind of octane boost or petrol or injcetor cleaner in your tank :) fill with BP ULTIMATE or SHELL VPOWER :) enjoy!
aviper4u
Postby aviper4u » Wed Aug 31, 2011 6:07 am
great to hear ,though a good tip mentioned to me in the past is to only wash the motor when its hot and running OR do what i do and avoid washing with water unless absolutely necesary.:)
Users browsing this forum: Bing [Bot] and 6 guests
