Painting rocker cover
- Vehicle: ND - 2
Hi guys,
I've just purchased a spare rocker cover, with the intention of paintin it up. Just wondering what methods people have used to paint theres, and if people want to post some pics up? sort of a show off your engine bay/rocker cover thread I guess?
Re: Painting rocker cover
VHT Wrinkle Red or Wrinkle Black would look good.
Wrinkle Red would make it look like an SE's rocker cover.
With the Wrinkle paint, to get the best wrinkle effect you need to bake it in an oven.
- Old Dude
Lokiel wrote:VHT Wrinkle Red or Wrinkle Black would look good.
And hope Mum Doesn't find out
MX 5 2001 Grace Green
NB8B
NB8B
- Vehicle: ND - 2
I was thinking of doing mine in wrinkle black, but i want to do the Mazda and DOHC part in different color, how should I do that, paint them first and then mask over it to do the black?
I've been wanting to do the same and in wrinkle black - apparently no need to bake that?
I will paint the lettering as well but figured it would be easier to do it after. Just let the rocker cover dry, then use a small syringe to dribble paint into the cavities. Will do it in silver to match the car.
Have a look here for some ideas/hints : http://clubroadster.net/vb_forum/showthread.php?t=10066
- gslender
VHT say the engine heat itself will also work... Just needs to be 100 deg for 20 mins.
G
- Matty
Did mine in VHT wrinkle black - no need to oven bake, but you could smell it curing when reinstalled on the car.
Prep was just a good clean with metho, applied then dried in the sun. A little help from a hairdryer I think too.
Matty wrote:Did mine in VHT wrinkle black - no need to oven bake, but you could smell it curing when reinstalled on the car.
I find that baking after each wrinkle coat produces better/more-pronounced wrinkles.
Also, don't call it a "hairdryer", we get enough crap about the MX5 being a hairdresser's car - it's "an entry-level hot air gun"
If you've got too much spare time ..
at the last Kurri Nostalgia festival there was an entire 50's aluminium aero caravan almost that good,dont know how they do it,find the time that is,or the determination not to quit when its only good enough.
Mick
Mick
Yeah i've got a little crazy with polishing parts in the past
Okibi wrote:Yeah i've got a little crazy with polishing parts in the past![]()
No kidding!
I took it off to paint while doing the timming belt.
I used the dishwasher to clean it with a bit of extra soap so all the oil was removed
Then I sprayed it and cooked it the oven to make it dry and wrickle up.
If I could do it again I would go black once you get a bit of oil on it its kinda hard to clean off.
every ounce counts
Anth from Build Threads has done a great "How to" for wrinkle paint here:
http://www.build-threads.com/general-car-stuff/diyhow-to-wrinkle-texture-paint/
