Few questions
Posted: Thu Jul 28, 2011 7:06 am
Ok i got a Series II NB
Question 1. COWL INTAKE how the F*** to do it with ABS (and the stupid washer bottle)
I want to make my own "cowl-style" intake.. How do i do it??
Whats the best way.
I will be using, stock intake piping to start off, heat shielded pod filter, and then a flexible hose. and .well.. whatever else i need after that.
atm my setup is just stock pipe, air filter, flexible hose that goes below the PASSENGER headlight into that hole where the wheel is.
Question 2. Increasing throttle reponse time
Ive owned this mx5 for a while now, after putting an exhaust on and changing the air intake, i realised i did increase the response time a little and it did help me enjoy the car as much as i enjoyed my old HONDA
How ELSE would i go about (light mods only) increasing the response time, i did some research before posting and it seems to me that shorter your intake is .. FASTER your throttle response is?
How would i shorten the intake and still get cold air though?
Would it be a good idea to .. put the pod filter AND then run the intake tubing? i dont think it'll fit but im sure you can buy smaller pod filters...?
Question 3. Wheel spin (whilst shifting)
I like it.. so i dont care about opinions my only question is .. what can i do to get BETTER Wheel spin atm i can JUST barely get it 1st - 2nd. Double Clutch can get it.. again.
Other cars, if you accelerate WHILST you depress the clutch shift and let go .. YOUR garunteed wheel spin it seems the mx5 is not.
Most cars that get good wheel spin seem to have a HD clutch, does this help? Or .. am i chasing ..rainbows
Whats the best way.
