Timing looks VERY wrong
Mxbob
Postby Mxbob » Sun Jul 24, 2011 2:42 am
Can anyone shed any light on this? Was checking my timing this evening. Car runs quite well, maybe a little sluggish and smells of unburnt fuel a bit.
Anyway if the timing marks on the case are at say 1oclock. My mark on the crank pulley is at about 10 o clock. Massively wrong.
Am I reading it right? Could the timing be out by this much?
Any ideas greatly appreciated!
1989 Eunos NA6 : BC racing coilovers : Flexible chasis : Unknown rollbar : Quirky 'banging' noise
JBT
Re: Timing looks VERY wrong
Postby JBT » Sun Jul 24, 2011 6:19 am
It could be a worn crankshaft keyway and/or an incorrectly set CAS. Which model car?
Postby NitroDann » Sun Jul 24, 2011 10:04 am
If you havent clipped the timing light onto the wrong lead, my bets on the crank pulley, it may have slipped between the pulley and the rubber dampener. So your timing may be right but your mark on the pulley has moved.
If its running anything close to right than this 30 odd degrees out is wrong. It simply cant be that far out and run ok.
Mxbob
Postby Mxbob » Sun Jul 24, 2011 10:19 am
Thanks for the input. Engine is a long nose 1.6 and it does run Ok. Just giving it a tune up.
I guess I need to check tdc with a dip stick in no1. At that point should the pully mark line up with the tdc mark on the belt cover or point straight up?
Postby NitroDann » Sun Jul 24, 2011 10:31 am
Tdc mark. If it doesnt then either the timing belt has slipped 8 teeth (it obviously hasnt) or the harmonic balancer has slipped on the press fit rubber.
Mxbob
Postby Mxbob » Sun Jul 24, 2011 12:23 pm
Thanks dan, if it's the harmonic balancer then I need a new pully?
Postby NitroDann » Sun Jul 24, 2011 1:58 pm
Id suggest it.
JBT
Postby JBT » Sun Jul 24, 2011 7:11 pm
Mxbob wrote:..Car runs quite well, maybe a little sluggish and smells of unburnt fuel a bit...
These terms are mutually exclusive. I wouldn't be surprised if you have a serious timing problem.
Postby NitroDann » Sun Jul 24, 2011 7:15 pm
30 degrees advanced, yet it still runs at all....?
Doubt it.
Mxbob
Postby Mxbob » Sun Jul 24, 2011 9:21 pm
Ok, checked the pulley marks by finding tdc with the dip stick in no1 cylinder.
Crudely marked the pulley with a new mark. Checked the timing and the new mark is showing about 18 degrees! Had it at 7k rpm earlier today :(.
The Cas was advanced about as far as it will go. I retarded the timing by about 5mm rotation of the Cas to put the timing at a more 'standard' setting. Will need a new pulley to get it spot on though as I know the dipstick measurement is not the most accurate.
Ho hum
Postby NitroDann » Sun Jul 24, 2011 9:28 pm
The dipstick method is accurate to a degree or 2.
So your saying that at TDC the marks show up at 18 degrees advanced? It should be at 0 degrees spot on. So your balancer has moved if thats the case.
Its will NOT affect performance at all. But its dubious over the long haul to leave it, and makes setting timing hard.
jerrah
Postby jerrah » Mon Jul 25, 2011 9:57 am
Kinda obvious question but you're setting to locked 10 degrees in the diag box if on stock ECU?
1991 MX5
Postby NitroDann » Mon Jul 25, 2011 10:24 am
It was showing 3 hours advanced (thats 30 degrees). The stock ecu NEVER goes past 33* at any point. It wouldnt matter if it was locked :D
Mxbob
Postby Mxbob » Mon Jul 25, 2011 12:38 pm
I'm a bit lost with the last couple of coments.
With everything as it was, I checked the timing and it looked about 30-40 degrees advanced.
I've since made a new TDC mark on the pully using the dip stick method.
I then warmed the engine, bridged the diag contacts, set the idle. Then checked the timing again and the new pully mark was showing at about 18 degrees.
I turned the cas about 5mm to get the timing back to around 12 degreed +/- 2 degrees and adjusted the idle to suit.
I thought bad things happen after 14 degrees?
Postby NitroDann » Mon Jul 25, 2011 1:33 pm
detonation CAN happen. And 14 degrees is the internets universally accepted safe limit.
Id say youll be ok. The sluggishness is probably due to detonation though. Ita not good, but its still running so you mustnt have done too much damage.
Obviously the slipped pulley hasnt affected the timing, that must have been a stupid PO or something.
