odd idle+rev issue
magenb
odd idle+rev issue
Postby magenb » Fri Jul 22, 2011 8:33 am
Drove home yesterday (~90mins) and everything was fine, stopped home for about and hour and then went to pick the misses up from the station. The car started fine but soon dropped down to 500rpm and eventually stalled. I had to keep on the revs up to stop it from stalling, and in driving it power was way down. It was like water had some how got into one of the chambers. Drove 5-10 minutes like this picked up the misses and stopped off at woolies with it still happening. Came out a few minutes later and it was all fine again.
Any idea's?
gslender
odd idle+rev issue
Postby gslender » Fri Jul 22, 2011 8:56 am
Failed temp sender? Ecu thinks engine is cold etc.
de Bounce
Re: odd idle+rev issue
Postby de Bounce » Fri Jul 22, 2011 10:46 am
Depends on what NB it is!
Known problems with intermittent idle/running are:
NB8A - could be coil packs or plug leads
NB8B - Cam Angle Sensor
Motorkhana Video
magenb
Postby magenb » Fri Jul 22, 2011 12:01 pm
its an NB8a, plugs and leads will be easy to change so I guess I'll start there.
spikes
Postby spikes » Fri Jul 22, 2011 12:37 pm
Postby 93_Clubman » Sat Jul 23, 2011 1:12 pm
In case it isn't plug leads, might be some leads here: viewtopic.php?f=29&t=47266
