Re: Engine Identification
Posted: Mon Jul 11, 2011 10:18 am
by 93_Clubman
1.6 or B6 engine = B6...... engine #
1.8 or BP engine = BP...... engine #
Posted: Mon Jul 11, 2011 10:19 am
by Boyracer
A BP is a 1.8
B6 is a 1.6
The engine number will start with either BP or B6
Posted: Mon Jul 11, 2011 10:32 am
by 93_Clubman
Correct - if BP is cast into the head it's also a BP, as a B6 head won't have BP cast into it as the official engine designations were B6 = 1.6 & BP = 1.8.
Another relatively easy way to tell is the B6 engine length is shorter than the BP, i.e. length of cam cover, or head, or block, or sump.
Posted: Mon Jul 11, 2011 8:24 pm
by Dezza Bot
I could have sworn I read somewhere that the BP was available as a 1.6. I'll have find where I saw it and link it here.
It's only wikipedia, so could be wrong :oops:
http://en.wikipedia.org/wiki/Mazda_MX-5 ... ifications
Posted: Mon Jul 11, 2011 8:25 pm
by Steampunk
So is the engine out of a JDM NB6 a B6?
Posted: Mon Jul 11, 2011 8:32 pm
by NitroDann
Yes.
Mazda made B series engines for many years from 87 odd to 2005/6 including the B1, a 1.1L single cam all the way to the bpze and turbo variants. if its 1.3L its a b3 if its 1.6 its a b6 if its 1.8 though, its a bp.
Its the same family, so cylinder bore spacing and crankcases all share virtually identical critical measurements, but theres no B6 thats also a BP.
Posted: Tue Jul 12, 2011 11:01 am
by project.r.racing
93_Clubman wrote:1.6 or B6 engine = B6...... engine #
this is a BP block in the pic. i believe the B6 engine number is located on the opposite side of the block.
Posted: Tue Jul 12, 2011 11:44 am
by jerrah
My B6 is out of a Japanese NB.
Has solid lifters and the sensors and thermostat outlet are different, otherwise looks very similar between years in the long nose crank.
Engine number is on the oil filter side for B6 and obviously starts with B6xxxxxxxx
Posted: Tue Jul 12, 2011 12:31 pm
by 93_Clubman
Dezza Bot wrote:I could have sworn I read somewhere that the BP was available as a 1.6. I'll have find where I saw it and link it here.
Indeed, it's wrong, at least in terms of most of the engine codes used. BP-4W was only used in 1998-2000 NB8A & 2004 NB8 SE. The following gives you a better idea, but overall there's still some inaccuracies & gaps: http://en.wikipedia.org/wiki/Mazda_B_engine#BP
