Engine drama - Stuttering under throttle - Oil pressure
Hjt
Postby Hjt » Sat May 28, 2011 6:32 pm
Hey all, I drove the car the normal 25km to work but put the car under more stress than normal IE hard on the accelerator.
Now i have developed a problem, my car has issues developing power between the 2000 to 4500 rpm range, stuttering as it increases.
My oil pressure has increased, and i'm about to go check my dipstick and read the levels.. I am afraid to drive it, and i have dríven it gentle to my girlfriends which is approx 4 km from work to check it out first before attempting to limp home.
It could be a coilpack issue that the other topic is discussing, but i believe the oil pressure wouldn't increase as a side effect..so i'm left wondering.
Mania wasn't answering calls today as it was prob closed, idle is fine at 900rpm when warmed up and the car is fine if im gentle on the throttle.
I'm no mechanic, and i dont here a misfire, but maybe i'm not getting the whole stroke. ??
Any ideas, gladly appreicated.
regards Hayden
Re: Engine drama - Stuttering under throttle - Oil pressure
Postby 93_Clubman » Sat May 28, 2011 7:20 pm
Where's Bruce? ok I'll it say: 'plug leads', if you haven't found anything to be a miss after checking the oil.
Hjt
Postby Hjt » Sat May 28, 2011 9:37 pm
Oil turned up fine, I will check plug leads tomorrow.. then coil pack arkk could get expensive.
If i clean the plug leads with my air compressor could i do more harm than good? I'll try and figure it out tomorrow.. last thing i need after a solid week.
Postby 93_Clubman » Sun May 29, 2011 1:02 pm
The usual problem with MX5 leads is that they deteriorate fairly quickly to the point where one or more's conductivity is affected. Doubt cleaning the ends with an air hose will help.
As you say, if not leads, could be the coilpack - on my old NA6 the inside of one or more of the coil posts, which the plugs leads fit onto, had deteriorated. 2nd hand one for NA6 about 10 years ago was $200, but should be cheaper now as a new one can be had for the same price:
http://www.cyberspaceautoparts.com.au/c ... _Coil.html
http://www.ebay.com.au/itm/MAZDA-MX5-NA ... 483ba5d29c
project.r.racing
Postby project.r.racing » Sun May 29, 2011 1:32 pm
sounds like leads to me. probably a pin hole in the solid section that goes between the camshafts. spark jumps to head instead of to plug when under heavy load.
Hjt
Postby Hjt » Sun May 29, 2011 8:26 pm
Thanks both for the awesome replies, unfortunately due to family circumstances i was unable to even touch the car today, hopefuly ill inspect the issue tomorrow. I think the coil pack will be the issue, shame :(
Postby 93_Clubman » Mon May 30, 2011 2:27 pm
If plug leads are arcing to camshaft cover enough it may be visible parked with the bonnet up at night with a few revs, but if it only happens under load then it may not be visible.
Dweezle
Postby Dweezle » Mon May 30, 2011 2:41 pm
Hey Mate
I could send you a Coilpack and leads that work if you want to try that?
If it works you could give me $100 for it if you wanted?, if it doesnt, send it right on back. :D
There just sitting around the garage.
Might help fix the issue for without forking out bucks for Maybes??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Patty
Postby Patty » Mon May 30, 2011 3:37 pm
Only when engine warmed up or all the time? Coil packs are usually more pronounced with a bit of heat. Otherwise I would agree with the leads comments.
LoL race you to see who can fix their car first. :lol:
Grace Green NB8A
Postby bruce » Mon May 30, 2011 3:55 pm
93_Clubman wrote:Where's Bruce? ok I'll it say: 'plug leads', if you haven't found anything to be a miss after checking the oil.
PLUG LEADS !
Hjt
Postby Hjt » Mon May 30, 2011 4:19 pm
Hey Dweezle, I will PM you regarding the items.
Thanks for all the suggestions, and Patty i hope we both get to fix our cars :)
Postby 93_Clubman » Mon May 30, 2011 6:39 pm
PLUG LEADS !
:mrgreen:
Hjt
Postby Hjt » Sat Jun 04, 2011 2:51 pm
FIXED
Four new spark plugs appeared to fix the issue. i'll keep you posted.
Thanks Mark for the coilpack and leads, ill work out the best way to return them shortly
