Having searched around the net, I've not found any NA6 cams? Why is that?
G
Which Cams for NA6??
- gslender
Re: Which Cams for NA6??
Guys in the states use these, lots of choice of profile - http://www.integralcams.com/miata.htm (there web site seems to be having issues at the moment)
Local options are here - http://www.tighecams.com.au/
si
si
NA6 B6T
- NitroDann
Any cam shop will have grinds ready or will be able to have custom ones made. My recommendation is to go to solid lifters then get some serious cams.
- gslender
NitroDann wrote: recommendation is to go to solid lifters
What down sides exist? I'm guessing it might sound a little tappety???
- NitroDann
Yeah, they will sound like older hla's, infact it will probably be quieter. They do need checking and adjusting every couple of years thats all. when they get noisy. but you can run MUCH more agressive cams with heaps more lift and duration without all the overlap that makes them hard to drive on the street.
- gslender
NitroDann wrote:you can run MUCH more agressive cams with heaps more lift and duration without all the overlap that makes them hard to drive on the street
I'm liking the sound of that !! ;)
G
