twin ignition setup and timing advance query
ctchme
Postby ctchme » Wed Apr 06, 2011 7:26 pm
hey guys,
I have a 93 mx5 clubman, and am about to install a new high powered ignition system, but was wondering if its possible to install 2 seperate systems, one that advances timing for faster acceleration around and out of corners, and another one that can be switched to that doesnt advance timing as much, for the straights
noobee
Re: twin ignition setup and timing advance query
Postby noobee » Wed Apr 06, 2011 11:18 pm
this can get the job done,as a standalone system or as in interceptor between your ecu and coil drivers.can carry two different maps(128 point each,i think).a friend had one connected to his lpg switch to provide more advance when he is on gas.works well.
Mick
www.jaycar.com.au/productView.asp?ID=KC5442
http://www.siliconchip.com.au/cms/A_108521/article.html
Postby NitroDann » Tue Apr 12, 2011 10:19 pm
WHAT!? Why would you want ANY of those things?
