NA8 Pre Ignition
rob323
Re: NA8 Pre Ignition
Postby rob323 » Fri Apr 01, 2011 12:24 pm
Air leak after the air flow meter?
Insufficient fuel pressure?
What's the base timing set at (with the pins connected in the diagnostics box)?
Are you using the correct timing mark on the crank pulley?
Don't drive it........RALLY it!
Postby manga_blue » Fri Apr 01, 2011 2:57 pm
When it was stock my NA8 absolutely refused to run on Shell V-Power. It would ping and miss for 200km then stop dead with hard little black nodules all over the spark plugs.
lukearama
Postby lukearama » Fri Apr 01, 2011 3:18 pm
manga_blue wrote:When it was stock my NA8 absolutely refused to run on Shell V-Power. It would ping and miss for 200km then stop dead with hard little black nodules all over the spark plugs.
What is with that???? Did you get an explaination???
Apart from Mazda............ trust nothing else...
rob323
Postby rob323 » Fri Apr 01, 2011 4:52 pm
It is the painted one on the left which should be used for timing.
