Re: running on 3 cyl after being jacked up
Posted: Sun Mar 27, 2011 11:05 pm
I would look at the mis-fire as an independent issue and not relate it to the jacking.
I had a similar thing happen to me after working on the car, turned out that one of the cylinders had flooded, coupled with a very fouled plug that would not fire. Was totally un-related to the work I did. Maybe check the plugs
Si
Si
