BP 1.8 Engine Details - For use in Engine Analyzer Software
Re: BP 1.8 Engine Details - For use in Engine Analyzer Softw
Postby manga_blue » Fri Mar 25, 2011 12:06 pm
So what are you up to, Dean?
Here's the link to Mazda's technical datasheets. Should have all the factory info you need for the NA8. Let me know if it's NB8 and I'll rummage around for those too.
http://mx5cartalk.com/forum/viewtopic.php?f=76&t=46376
Postby 93_Clubman » Fri Mar 25, 2011 1:12 pm
Dean, any particular MX5 (or other Mazda) BP engine variant?
For example:
BP-ZE (with BP05 head): 93-97 MX5 NA8;
BP-4W (with BP4W VICS head): 98-00 MX5 NB8A;
BP-Z3/ BP-VE (with BP?? VVT head): 00-04 MX5 NB8B & NB8C; &
BP-4W: 04-05 MX5 SE (Turbo).
Postby 93_Clubman » Fri Mar 25, 2011 1:20 pm
Dean_H wrote:Not up to anything...yet. ;-)
some of that info helps for sure. Thanks. NB8 also would be great if you have it.
Depending on what you're planning, Woo's posts in the following might be of interest:
viewtopic.php?f=29&t=32589
viewtopic.php?f=29&t=32572
Postby manga_blue » Fri Mar 25, 2011 1:58 pm
Here's the NB8B VVT one. Virtually nothing useful for you there though.
01-50 TECHNICAL DATA.pdf
The NB8A is pretty similar to the NB8B, i.e. just tune-up specs, not build specs. The full NB8A manual should still be at http://mx5cartalk.com/forum/viewtopic.php?f=76&t=37363 and the Technical Data is buried in that.
Have you hunted around http://forum.miata.net and http://www.miataturbo.net/ yet?
