Terrible sound at 3200revs
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Re: Terrible sound at 3200revs
can you describe the sound?
- de Bounce
Sounds like a guard or shield has cracked and at the correct revs it vibrates and makes the noise.
- Jeo
I had a similar problem but it was more like 2000-3000rpm and a grinding/knocking noise. Ended up being that the bolt that holds the pulley wheel on the water pump had seized.
yh, check all the heat shields and guards down the exhaust system for loose and rattling bits.
- 7Hazi
Check your cat - might be old and the internals have fallen apart (I have a similar problem on my car).
