Torn gear shift boot - help please
Posted: Sat Mar 05, 2011 3:23 pm
by snshami
Hi, I took my console off to replace my head unit and noticed a torn gear lever boot. It seems to be held on the gear lever with a nylon ring. I could not find an obvious way to remove the nylon ring.
How does one replace this boot. Is there a boot below it is as well. Should this be replaced as well. Should i do anything else while I am doing these things such as lubricate the gear lever linkage?
Does anyone know what the cheapest source for these boots is in Melbourne. How much would I be looking to spend.
Re: Torn gear shift boot - help please
Posted: Sat Mar 05, 2011 3:32 pm
by JBT
snshami wrote: Is there a boot below it is as well. Should this be replaced as well. Should i do anything else while I am doing these things such as lubricate the gear lever linkage?
Yes, yes and yes. See link:
http://forum.miata.net/vb/showthread.php?t=398211&highlight=gear+lever+bootBuy the boots from Mazda or import them.
Posted: Sat Mar 05, 2011 3:36 pm
by snshami
Thanks. Any idea how much Mazda charge for them.
Posted: Sat Mar 05, 2011 4:04 pm
by Regie
from memory
i got my last set from mania for $30 and $45 for the bigone
Posted: Sat Mar 05, 2011 4:58 pm
by Mr Morlock
best way to find out what they cost is ask Mazda and or the MX5 factory ( just a phone call(s) ) - cost will not dictate the need for replacement. I really good idea for diy is getting a repair manual.
Posted: Sat Mar 05, 2011 5:13 pm
by snshami
Mr Morlock wrote:best way to find out what they cost is ask Mazda and or the MX5 factory ( just a phone call(s) ) - cost will not dictate the need for replacement. I really good idea for diy is getting a repair manual.
You are right, of course. I wasn't trying to be lazy. Unfortunately Mazda Spare Parts closed at 12.00 noon today and MX-5 Factory don't have their parts people working on Saturdays either. I was merely wondering whether it would make sense for me to have the parts sent from overseas or buy them from here.
Posted: Sat Mar 05, 2011 6:32 pm
by Bauer
The mania newsletter this month has both boots and the nylon bush for $84 for the 5 speed
I most certainly did the bush when i did my boots. All are 'consumables'
Posted: Sat Mar 05, 2011 7:02 pm
by Mr Morlock
MX5 factory is likely to have them ex stock and some of the Mazda spares centres are likely to have them as well or within a day or two. I would guess MX5 factory prices will be much the same as Mazda.
Posted: Fri Mar 11, 2011 12:37 am
by snshami
I ended up buying them from a member of this forum for a great price and installed them today. Installation was a breeze. I think I may not have pushed the white ring on the big boot down low enough on the shaft because the boot makes a kind of a popping sound when changing in and out of 3rd and 4th gears. The popping sound is happening because the boot is changing shape.
Posted: Fri Mar 11, 2011 7:45 am
by JBT
snshami wrote:...the boot makes a kind of a popping sound when changing in and out of 3rd and 4th gears. The popping sound is happening because the boot is changing shape.
Mine did that too and I fashioned a tube out of a paper towel roll inner (toilet roll might work too) and reinforced it a little with race tape. That keeps the boot shape and stops it "popping". The original set-up had a a cardboard tube type of thing that fitted over the gear lever and the top of the boot - see photo.
Posted: Fri Mar 11, 2011 5:08 pm
by broady
Posted: Fri Mar 11, 2011 7:13 pm
by snshami
An update:
When I got home today I took the console off and lowered the nylon collar by about a 15mm. After that I tried it and the noise was gone. Hopefully this will help someone.
Posted: Fri Mar 11, 2011 8:18 pm
by CheyneX5
The noise occurs because the collar was not low enough, as you discovered. A simple fix that's easy on the mind.
Posted: Fri Mar 11, 2011 8:54 pm
by JBT
Be careful; pushing the collar down too far will cause the boot to get squished on every gear change it may rip again after a fairly short time.
Posted: Fri Mar 11, 2011 10:31 pm
by snshami
JBT wrote:Be careful; pushing the collar down too far will cause the boot to get squished on every gear change it may rip again after a fairly short time.
I have put the foam sleeve in place that should help a bit. I also have liberally sprayed the rubber with lithium grease and wd40 so it cannot abrade itself.
