im wondering if its worthwhile using adj cam gears.
its a mod i dont have and havent found much info on them. can anyone shed me some light?
na6 adjustable cam gears
- Learner Driver
- Vehicle: NA6 - Turbo
Re: na6 adjustable cam gears
supermiata wrote:im wondering if its worthwhile using adj cam gears.
its a mod i don't have and haven't found much info on them. can anyone shed me some light?
Ok, Question time.
Do you have aftermarket cams or are you planing on playing with the std units?
Do you have an aftermarket ecu?
The reasons I ask is you can use adjustable gears on a std motor but you need to understand that its takes a fair bit of time to adjust the gears if your running a std rocker cover. On my first dyno tune we had the rocker off probably 4 or 5 times just farting around to see what and where we could improve.This was after the cams were dialed in after the refresh!!!At $150 per hour it can run up your cost
Would I worry about this on a roady, Nah!!! tooo much farking around for "some" improvements, but on a track queen certainly helps.
They do LOOK pretty though
Terry
lol thats why i run a cut rocker cover for quick and easy adjustment, that wouldve really sucked!
- NA6 Turbo: GT2554, Greddy cooler, 4.1 "CIG Locker", Bilstein coilovers, N2 flared guards.
- NitroDann
Adjustable cam gears help you to widen the cam angle , tighten it, advance and retard it. In essence widenign it helps broaden torque curve, tightening tends to comcentrate it over a point and advance/retard moves it up and down the rev range. You SHOULDNT need adjustable with aftermarket cams because they should already be right for you just like you asked for and paid for.... But yeah i still have them.
