O-RING - NA6 Lower Thermostat housing
Dweezle
Postby Dweezle » Wed Feb 16, 2011 10:51 am
Hey all.
I desperatley need a o-ring for the lower thermostat housing on for a 1.6.
MAzda can't/wont help as they said i would need to buy the entire lower housing. :x
I do not want to use the wrong one as its quite a task to get back in there if it leaks and worse if it happens to break the ears off the housing.
Does anyone have one floating around or know of where i can get one?
I am waiting for MANIA to get back to me.
Thanks in advance
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
zossy1
Re: O-RING - NA6 Lower Thermostat housing
Postby zossy1 » Wed Feb 16, 2011 11:09 am
Should be able to pick one up for a couple of bucks from Repco, etc.
I have an old one here that you can have as a guide - but I'm a fair ways from you Dweezle :). If you can pull your old one off, should be pretty easy to match it.
Be sure to install it carefully to avoid it rolling out of place, and with some gasket goo (not silicone!) to get a good seal.
tbro
Postby tbro » Wed Feb 16, 2011 7:26 pm
P/N #B61P-15-106
Thats the part number you require Mark, ring em and tellem to order it in, or be a sneaky buggar and ring Ford and order it from them.
Terry
Dweezle
Postby Dweezle » Thu Feb 17, 2011 7:10 am
Terry you the Man!!!!
Highfive :)
Jeremy Clarkson
