I found on miataturbo a formed coolant pipe that is an almost perfect fit for the MX5 coolant reroute.
Part number is: dayco e71989
http://www.miataturbo.net/showthread.php?t=46698
It was a bit difficult to locate in Australia being out of a GMC truck but Eagle Spares in springwood stocks them.
Coolant reroute hose (formed pipe)
- jerrah
1991 MX5
- Vehicle: ND - 2
Re: Coolant reroute hose (formed pipe)
Excellent find.
- Locutus
whoa, that's awesome. thanks!
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
MX5 Plus in Brisbane also do an aluminium re-route pipe (hotside) which I used - with a couple of sections of flex hose it works just fine.
- jerrah
Uncle Arthur I'm using the MX5plus spacer which outputs my coolant on the coldside? The rubber pipe has all the right bends around the intake - works well.
I was previously using various bits of pipe and a piece of flex to do the bend. I was plagued with little leaks so one pipe all the way really sorts me out.
1991 MX5
- Vehicle: ND - 2
Uncle Arthur wrote:MX5 Plus in Brisbane also do an aluminium re-route pipe (hotside) which I used - with a couple of sections of flex hose it works just fine.
For 20 bucks?
- Uncle Arthur
I didn't recall the OP stating a price.....
However - no - not $20 but then again if you are really balking at spending $ on your modded 5, you could always buy your own length of ally pipe at the right size and make your own.
- jerrah
The pipe I bought wasn't $20 either. If you can find them cheaply in Australia let me know!
1991 MX5
