Misfire Cause Found
davamb
Misfire Cause Found
Postby davamb » Sat Jan 29, 2011 9:26 pm
Been a while since I've spent any time or money on the old thing, now trying to make good with a new water pump (thanks Morris) yet to be fitted and some effort into chasing a misfire that's been steadily worsening.
Today I found the cause of the misfire and I'm really not best pleased, to put it mildly.
Have a look at this:
Not long after I bought it I had new leads and cambelt fitted as I wasn't sure of the age of these parts. Now what the mechanic's done is used straight (instead of right-angle connectors) in the plug set and not pressed the metal inner home into the ignition coil pack on two pots. The plug shrouds are right-angle and straight connectors could certainly be used as has been done on the remaining two pots, but on the two that haven't - this is the result. The metal inner has been sitting at the top of the coil pack outer and the spark has just been jumping the gap or tracking the inside of the dielectric (more likely). Have a look at what it's done to the insulator - it was just dust! I am simply staggered that the car ran so long so well - phenomenal. Absolutely amazing.
What I don't know is if this was how the lead set was originally fitted or if it has been done in a subsequent service so I can't apportion blame. I'll see if I can build up the lost material with some epoxy compound or similar, but I feel the real solution is going to be a new coil pack.
So time to ask assistance of one and all - anyone got a decent second-hander sitting around in Melb??? Also anyone recommend a decent mechanic to replace the water pump - I just don't have the time or workspace at the moment. (Tony at FulTech doesn't seem to be answering his calls, maybe on hols?)
Thanks in advance.
Cheers, Dave, 1990 NA6
Via est vita.
ak_perth
Re: Misfire Cause Found
Postby ak_perth » Wed Feb 02, 2011 6:35 pm
Sorry to hear about your problems.
I burnt my coil pack out last autumn on my Clubman by leaving the ignition on by mistake.
I called MX5 Mania and they had a second-hand coil pack for my car in stock. The guaranteed it worked and i got it at a fraction of the price of a new one. Mazda dealers wanted $800 for a brand new one. Unbelievable price :shock:
Anyway it arrived after 3 days, very fast for Perth, and it works perfectly. So if you cant find a second hand one in Melbourne try MX5 Mania.
AK
davamb
Postby davamb » Thu Feb 03, 2011 10:01 am
Bought an old head with ignition pack attached off Entice a couple of nights ago and exchanged packs last night. All sorted. Big thanks to all who offered help.
Via est vita.
Entice
Postby Entice » Thu Feb 03, 2011 6:36 pm
good to hear all is fine! hope it runs better!
More opportunities have been lost from indecision, rather than wrong decision.
