NA6 Engine Replacement
Re: NA6 Engine Replacement
Postby 93_Clubman » Fri Jan 21, 2011 12:20 pm
Stag76 wrote:Apart from the flywheel, are there any other differences in these engines (eg TPS).
Indeed, understand the auto NA6 B6 motor had a different TPS, but perhaps more importantly it had lower compression pistons, different cams, less peak HP, & torque at lower RPM: http://www.solomiata.com/Mx5Engine.html
Dorimx5
Postby Dorimx5 » Tue Jan 25, 2011 1:15 pm
if the tps is different you should still be able to convert the current loom to suit the new tps
project.r.racing
Postby project.r.racing » Thu Jan 27, 2011 9:07 pm
or just replace the engine only. ie, cam cover, head, block, sump. everything else you keep from the original car.
don't go chopping stuff and swapping stuff you don't need to.
corners
Vehicle: ND - Supercharged
Postby corners » Fri Feb 25, 2011 10:13 am
project.r.racing wrote:or just replace the engine only. ie, cam cover, head, block, sump. everything else you keep from the original car.
I agree with this.
Swap bare motor for bare motor
