Replacing Power Steering Fluid
sticky nicky
Postby sticky nicky » Sat Jan 08, 2011 8:38 pm
Hi,
I was replacing the cooling system hoses and accidently cut through a power steering pipe which was directly underneath one of the hoses that I never saw :oops:
I replaced the damaged hose and refilled the power steering fluid. I ran the engine and turned the steering from lock to lock a few times and checked the level after.
My question is: did I do everything right or is there a correct procedure for doing the power steering fluid ???
Re: Replacing Power Steering Fluid
Postby manga_blue » Sun Jan 09, 2011 5:35 pm
AIR BLEEDING
1. Check the fluid level
2. Turn the steering wheel fully to the left and right several times with the engine not running.
3. Recheck the fluid level. If it has dropped, add fluid.
4. Repeat steps 2 and 3 until the fluid level stabilises.
5. Start the engine and let it idle.
6. Turn the steering wheel fully to the left and right several times.
7. Verify that the fluid is not foamy and that the fluid level has not dropped.
8. Add fluid if necessary and repeat Steps 6 and 7.
de Bounce
Postby de Bounce » Sun Jan 09, 2011 6:27 pm
manga_blue wrote:2. Turn the steering wheel fully to the left and right several times with the engine not running.
I have found it helps if you raise the front wheels slightly off the ground, makes turning the steering wheel easier.
Motorkhana Video
sticky nicky
Postby sticky nicky » Mon Jan 10, 2011 2:21 am
Thank you for your replies :D
Purfler
Postby Purfler » Wed Jan 12, 2011 5:39 pm
Putting sheets of newspaper under the wheels is another way to make it easy to turn them.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
Users browsing this forum: No registered users and 57 guests
