6spd installed....speedo out !
Posted: Fri Jan 07, 2011 7:32 pm
by wazman
Hi all,
I installed a 6spd a while back and the speedo is out by 20klm....... am i ment to swap the 5 spd speedo sensor into the 6 spd ? or what do i change to make it right ??
any help appreciated
Cheers Waz
Re: 6spd installed....speedo out !
Posted: Mon Jan 10, 2011 10:28 pm
by Divo
There are at least 4 different speed sensors depending on diff and gear ratios. Because the 6 speed is different to your 5 speed you'll need to change to the right sensor. See the link:
http://s637.photobucket.com/albums/uu94 ... nsors2.jpg
Mazda should be able to tell oyu which one is correct in a 6 speed (I think it's the green one)
cheers
Mark
Posted: Tue Jan 11, 2011 12:16 am
by orx626
wazman wrote:am i ment to swap the 5 spd speedo sensor into the 6 spd ?
Cheers Waz
Yes, if you have not changed the diff ratio from what was originally behind the 5-speed.
