Hi all,
I installed a 6spd a while back and the speedo is out by 20klm....... am i ment to swap the 5 spd speedo sensor into the 6 spd ? or what do i change to make it right ??
any help appreciated
Cheers Waz
6spd installed....speedo out !
- wazman
ilovedrift.com
- Vehicle: ND - 1.5 GT
Re: 6spd installed....speedo out !
There are at least 4 different speed sensors depending on diff and gear ratios. Because the 6 speed is different to your 5 speed you'll need to change to the right sensor. See the link:
http://s637.photobucket.com/albums/uu94 ... nsors2.jpg
Mazda should be able to tell oyu which one is correct in a 6 speed (I think it's the green one)
cheers
Mark
cheers
Mark
- orx626
- Vehicle: NC - Rotary
wazman wrote:am i ment to swap the 5 spd speedo sensor into the 6 spd ?
Cheers Waz
Yes, if you have not changed the diff ratio from what was originally behind the 5-speed.
Users browsing this forum: No registered users and 52 guests
