Not a great lot of detail and US focused
At about the 4.30 min he mentions that Mazspeed used the 99-00 engine over the VVT
You missed a BPT from a BG8Z Familia, and the BG and BA Astinas run a same BP as NA8 BP engines.Borked wrote:http://www.billzilla.org/4agmods.htm
Is there a website that lays out modification paths for the BP like the above does for the 4age (big and small port) 4agze and 4age 20v ?
What's the difference between the following and which engines best for the purpose of being forced fed ?
Should clarify that opening the engine up to upgrade internals is planned, so can live with a N/A BP if it has more potential due to the heads or the like.
1.8 SVT
1.8 From 98-2000 High Port
1.8
Are there any versions I've missed ?
