NB intake pipe onto NA - slight mod needed?
Posted: Mon Dec 13, 2010 9:13 am
by evil_weevil
So I have upgraded the pipe,
As you can see with the pics I am having one trouble with one of the mini pipes/hoses that come off it.
so 3 quesions!
1. what does it do?
2. do I need it?
If I do need it - whats the best way to put the hose into the intake pipe?
As you can see with the photos, I have circiled them with my awesome paint skillz hehe
Cheers!
Chris
the first photo has the old NA pipe with the inlet bit for that hose
Re: NB intake pipe onto NA - slight mod needed?
Posted: Mon Dec 13, 2010 10:30 am
by 93_Clubman
Chris, it's for cold start - found it needed to be connected to the intake crosspipe otherwise wouldn't run - Here's an old pic of mine:
Merged the two different diameter pipes into one using a reducer & a T junction - or you can put a filter on the cam cover vent & then just connect the TB IAC cold start pipe to the intake crosspipe.
Don't believe you can put a filter on the end of the cold start pipe (& replace both retaining clips to more securable ones), as the IAC seemed to want flowing/ pressurised air from crosspipe.
Btw, have a white hail damaged bonnet from a Clubman if you want it - no paint damage, just lots of dints!
Posted: Mon Dec 13, 2010 12:27 pm
by fattima
I drilled the intake pipe and fitted an black irrigation pipe elbow that was the same diameter. The elbow has a flare on the end so it seal well on the inside of the pipe. I glued the elbow in with Loctite plastic glue (similar with super glue and also put a seal of black silicon around the join on the outside only. I've been running that setup for about a year now with no problems.
I can take some pics when I get home if you like.
Posted: Mon Dec 13, 2010 12:44 pm
by evil_weevil
Awesome replies, thanks guys really appreciate it :)
93_clubman - I have my old small airfilter from my old catch can from my R33 days at home, thats a good option to do!
just gotta find a T piece!
fattima - yeah if you could post a photo too that would be really awesome!
Thanks heaps again guys,
Chris
Posted: Mon Dec 13, 2010 2:37 pm
by 93_Clubman
Chris, a temp fix is to use a piece of hose whose OD is close to the ID of the cold start pipe - that way you just feed the narrower pipe into the cold start pipe far enough so that a pipe clamp can be placed over the larger pipe to tighten it around the narrower pipe. Then just connect it to intake crosspipe centre protrusion, & fit a filter to the cam cover breather - no T piece or reducer required.
Posted: Mon Dec 13, 2010 8:36 pm
by fattima
Twenty cent fitting from Bunnings, maybe not that elegant but works. Sorry for the dodgy phone pic.
Posted: Tue Dec 14, 2010 1:11 pm
by evil_weevil
Awesome,
Thanks lads!
I picked up my old catch can air filter and put that on - tomorrow morning before work is hoses and clamps!
oh, 93 clubman - thanks for the offer for the bonnet mate but got one this morning, red too!
hopefully car on road by weekend yay!
Posted: Fri Dec 17, 2010 12:21 pm
by evil_weevil
So got it finally sorted today!
my mate who is a fiter and turner made me a cheap reducer and then got the oil catch can air filter/breater
put it all on and works!
now to put my bonnet on tonight haha
Posted: Fri Dec 17, 2010 2:34 pm
by 93_Clubman
Good stuff Chris!
No probs re bonnet - when I read you were after a white one, thought might as well let you know have hail damaged one sitting in the garage, even though logistics wouldn't have been simple.
