Gearbox mounts.
wun911
Re: Gearbox mounts.
Postby wun911 » Tue Nov 30, 2010 6:26 pm
you mean engin mounts???
every ounce counts
Hellmun
Re: Gearbox mounts.
Postby Hellmun » Tue Nov 30, 2010 6:28 pm
The gearbox bolts to the PPF so it doesn't have conventional mounts like you'd find in most other RWD's that I've seen. The only replaceable mounts are on the diff and engine.
Those can both be replaced with harder mounts which are good for track/drag but generally not required for street driving.
Re: Gearbox mounts.
Postby manga_blue » Tue Nov 30, 2010 8:56 pm
Mazdaspeed mounts work well both front and back. Slightly stiffer than OEM, but same type of construction. They're are a better and cheaper choice than OEM for when your old mounts are stuffed. http://www.good-win-racing.com MX5Mania routinely fit them as stock replacements too.
Nolathane (eg Energy Suspension) diff mounts are for racing use only and make the car impossibly harsh and noisy for road use for no real benefit.
ducktape69
Re: Gearbox mounts.
Postby ducktape69 » Sat Dec 04, 2010 11:35 am
I've had the mazdaspeed mounts fo about 2 years now. Stiffer than OEM. Crisper shifting feel. Slighly more 'buzzy' idle though.
Users browsing this forum: Bing [Bot] and 59 guests
