RPM drop from airconditioner
Noddycar
Postby Noddycar » Wed Nov 17, 2010 6:09 pm
Hi all
I am sure this is just a fact of life with an NA, but every time my aircon cuts in I get a relatively large drop in RPM's, especially at low speeds coming up to lights etc. This can cause a bit of jerkiness and is more an annoyance than a real problem, but I was wondering if anyone had a fix to reduce the problem. I know the car get a power drop when the a/c compressor kicks in (hey, it is just a wee little 1.6!), but I wondered if there was any method of softening the drop a little....? I am not overly concerned, because it is really only at lower RPM's that the change is aggressive. At higher RPM's, the car just loses a little power and is not as noticeable.
Thanks in advance.
1993 MX-5 Limited Edition - my original Noddy Car
2010 Roadster Coupe Sport - the more civilised (but still fun) daily driver
project.r.racing
Re: RPM drop from airconditioner
Postby project.r.racing » Wed Nov 17, 2010 8:12 pm
clean the IAC.
Noddycar
Postby Noddycar » Thu Nov 18, 2010 10:53 am
Thanks for the reply..... I'll check this out on the weekend and see if it helps.
