Diagnosing a coolant leak
Posted: Fri Nov 05, 2010 11:28 am
After putting up with a slow leak of coolant over recent months (~70mL/hr while driving or as engine cools), I finally got around to taking off the undertray from my NA6 this morning so that I could track down the source of the leak. Judging from the photos below, it seems to be mainly coming from behind the crank pulley.
OK, give me the bad news. Is it the water pump? Wouldn't surprise me if it is because I suspect it wasn't replaced when the timing belt was done (long before I took ownership). If the water pump has gone, then I might as well get the timing belt done at the same time since it appears that it needs to be removed it to get access anyway.
Viewed from underneath
IMG_0329 by Guran5, on Flickr
Viewed from the top
IMG_0332 by Guran5, on Flickr
Viewed from the top
