CAR IDLE ENGINE REVS
Posted: Thu Oct 21, 2010 12:38 am
by blackant
After 35mins driving, mix of traffic, all of a sudden the accelerator steps down a little and the revs climb to 1600rpm. They will stay there, intermittently dropping back to idle then returning back up to 1600rpm.
If you leave the car for a while and return everything is normal. Not related to fans coming on either.
Sensors or air intake?
Any ideas?
Thanks
Re: CAR IDLE ENGINE REVS
Posted: Thu Oct 21, 2010 7:05 am
by fattima
Presume you have an NA6 or 8? (Helps if you put this info when posting in the future)
http://www.miata.net/garage/KnowYourCar/S7_Idle.htmlSearch the forum too, it has been gone over heaps of times.
Posted: Thu Oct 21, 2010 1:52 pm
by blackant
Oversight.
1989 NA6 STANDARD INTAKE/EXHAUST
Revs are rising NOT dipping
Posted: Thu Oct 21, 2010 2:41 pm
by gobsmax
coolant sensor on back of engine block
Posted: Thu Oct 21, 2010 4:28 pm
by fattima
blackant wrote:Revs are rising NOT dipping
Did you read the link properly, revs rise THEN dip. I've had it happen. Easy thing to check and a fairly common issue.
Posted: Fri Oct 22, 2010 12:29 am
by blackant
Fattima - Yes i did read it, something which you appear to be incapable of. The revs rise and never drop below idle CLEARLY STATED. This continues and is not related to being at a stop, again 'stop' is CLEARLY NOT MENTIONED. The 'link' is related to the idle, mentions taking your foot off the accelerator when I CLEARLY mentioned the accelerator actually moves in a downward direction. The 'ambient-mechanical' setting isn't relevant as I CLEARLY mention that it goes back to idle.
Thanks gobsmax, will start there.
Posted: Fri Oct 22, 2010 7:03 am
by fattima
Wow.
Enjoy chasing problems on your car, don't think you will find many people wanting to help you out with your attitude. So let me CLEARLY state that you are a hottie.
Posted: Fri Oct 22, 2010 11:21 am
by GP
I've heard of the idle dip several times which mine does but I've never heard of your problem.
And I don't blame you for your retort, There's some stirrers on here like evrey forum
