Can a na8 diff fit onto a na6 ?
Just plain swap?
na8 diff into a na6
- orx626
- Vehicle: NC - Rotary
Re: na8 diff into a na6
Yes. However, you also need the NA8 half shafts.
....and if you change the diff ratio you will need the speedo drive from the gearbox that matched the NA8 diff.
- johnd
And tailshaft. Just done this swap!
Life is something that happens when you can't get to sleep.
Thanks for the help guys.
All done just swapped for a na6 diff in the end.
