nb6 engine info - help needed
Posted: Sun Oct 17, 2010 5:17 pm
hi guys
i've purchased a nb6 engine to slot into my na6. included in the sale was the loom and ecu, and maf.
i haven't had much luck with internet searches on the differences between the na6 and nb6 engine, what components are different / better, and what is the best way to do the swap. however it seems that the most common and simplest approach is just to use the na6 ecu and running gear (afm, cas etc) and swap it onto the nb6 engine.
i'd prefer to use the nb6 ecu and maf if possible. it seems like a more elegant solution. but maybe it's more trouble than it's worth? or should i just get a megasquirt..... ?
the other thing i'm wanting to do is chuck some cams in it. the nb6 has solid lifters and i'm not sure if most of the cams on the market (which are made for the na6 engine with hla's) are compatible. can someone help me out here? are they compatible or will i need to source some cams that are made specifically for the nb6... coz i'm not aware that any such cams exist
anyway, any help in pointing me in the right direction in regard to info on the nb6 engine would be appreciated. surely there's some forums or other sources of info on the interwebs somewhere that can answer some of my questions as to how i should proceed.
cheers
cheers
