NA6 Thermo Switch connector
Gazbo
Postby Gazbo » Sat Oct 16, 2010 5:40 pm
Does anyone know where I can source the electrical connector (item 1 on the diagram) for the thermo switch ?
Are these standard electrical connectors that I could source from an auto-electrician ?
My connector has disintegrated.
Thanks!
toimr2
Re: NA6 Thermo Switch connector
Postby toimr2 » Sun Oct 17, 2010 10:39 pm
So has mine.
I would like to know as well
Gazbo
Postby Gazbo » Mon Oct 18, 2010 6:00 pm
These connectors seem impossible to source - as they are part of the car's wiring loom the only option would seem to be buying the entire loom from a wrecker.
My bare metal connector is just slid over the thermo switch's single pin, the connection is OK for a while but eventually it looses contact and the fan stops running causing overheating in traffic.
A quick wiggle of the connector fixes it again, for a short while...
rwf
Postby rwf » Mon Oct 18, 2010 6:07 pm
just earth the wire fan will run all the time when engine is running
SOLD. MX-5 NA 2F RACE CAR -LAKESIDE 1:04.91 -QR Clubman 1:06.3608
SOLD. Mx-5 NC 2007
Mazda 3 sp25 2015
MX-5 NB
tbro
Postby tbro » Mon Oct 18, 2010 7:55 pm
Try http://www.bmotorsports.com
you will need plenty of patience and good eyes, but they can usually supply all those little things that no-one else can.
