NA6 Power Steering belt
hot rod
Postby hot rod » Thu Oct 07, 2010 11:50 am
Hi guys,
Just wondering if an NA6 Power Steering belt is the same as the NA8, need to replace it.
Thanks
Luke
Re: NA6 Power Steering belt
Postby 93_Clubman » Thu Oct 07, 2010 12:00 pm
there are differences in crank pulleys, & i don't believe the crank pulleys are interchangeable, so the belts might be likewise.
hot rod
Postby hot rod » Thu Oct 07, 2010 12:03 pm
Thanks for that.
I didn't realise local NA6's were sold with factory PS so I should be able to track one down ok now.
Postby 93_Clubman » Thu Oct 07, 2010 12:06 pm
my old '89 didn't have ps, but the later ones i believe did - might be worth checking new one against you're old one as there were differences in pulleys from SNC to LNC, which may or may not have affected belt length.
Purfler
Postby Purfler » Fri Oct 08, 2010 4:06 pm
The Limited Edition NAs had powersteering.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
hot rod
Postby hot rod » Fri Oct 08, 2010 4:22 pm
Thanks, well I got a P/S belt for a 1990 model so hopefully it all fits fine.
I boilded the fluid at the last track day so am going to put a cooler on it as well.
