Seeking advice - NA6 excessive oil usage / PCV?
Guran
Vehicle: ND - 1.5
Re: Seeking advice - NA6 excessive oil usage / PCV?
Postby Guran » Sun Oct 03, 2010 5:33 pm
Would be worth doing a leakdown test to check compression.
Steampunk
Postby Steampunk » Sun Oct 03, 2010 8:05 pm
Try unplugging the PCV hoses, plug-up the tubes on the intake plenum and intake pipe, and install PCV filters (those mini pod-filers) on the cam cover.
If you still notice smoke on start-up and hard acceleration, then it's NOT the PCV system.
It'll be a new one for me if a faulty PCV causes that much oil usage.
Have you looked inside the plenum to see if it's filthy with oil?
