Hi
i am removing the AC and wondering whether the AC Fan is required to go back on and would it work in parallel with the normal radiator fan. I am after as mocuh cooling as possible so if it runs together then my choice would be keep it.
Thanks
AC Condensor Fan Question
- Garry
Re: AC Condensor Fan Question
You will have to do some re-wiring to get both fans to work as the A/C fan only works when the A/C compressor kicks in. Or in the case of the SP and probably the SE it will come on when things get really warm.
Thanks for the reply - i should mention its an NA
I was guessing it may be on a seperate relay- wondering how people have rewired as I would like to have both running
