NA6 Hydraulic Lifters
Charlie Brown
Re: NA6 Hydraulic Lifters
Postby Charlie Brown » Thu Sep 16, 2010 9:25 am
Stag76 wrote:The hydraulic lifters on my NA6 engine
:shock:
Your engine doesn't have any. It has overhead cams. 8)
Changing the engine oil and filter can reduce the cam follower noise. This is a very common complaint amongst NA owners.
Your blue smoke is either rings or valve stem seals.
GP
Postby GP » Thu Sep 16, 2010 1:23 pm
Plenty of OHC engines have hydraulic lifters, Are you saying that it has solid lifters?
Sometimes on cold startup they are particularly noisy, and this is followed by a cloud of blue smoke at the exhaust
Valve stem seals
Graham
adamjp
Postby adamjp » Mon Sep 20, 2010 1:44 pm
Valve stem seals
+1 valve stem seals, possibly even a burnt valve. The cloud of oil smoke is distinctive and will not occur from lifters alone.
Adam
s13deviat
Postby s13deviat » Thu Sep 23, 2010 8:53 am
I have just had this terrible lifter noise hit my engine, not just on start up but all the time now.....
I bought the car 3 weeks ago and it was WEEELLLLL overdue an oil service, but didnt have noisy lifter. Did an oil change to 10w60 and now it just doesnt stop 'tapping' away!!!! Wasn't gradual, just one morning started her up and wham, there it is, wont go!!! :cry:
Might try that lifter additive stuff and maybe a different oil.... dunno...
SKYHI
Postby SKYHI » Thu Sep 23, 2010 11:18 am
s13deviat wrote:I have just had this terrible lifter noise hit my engine, not just on start up but all the time now.....
Definitely worth a try. The engine in my track car has about 142,000ks on it, and on a couple of ocassions when it's sat idle for a month, the lifters will be a bit noisy. Usually change the oil every 3 race meetings anyway, but each time a fresh oil change has cured the lifter noise. The last time I started the car however, the lifter noise hadn't stopped after a couple of minutes so I thought they might be getting a bit sticky, so I put in some fresh oil and some Nulon Lifter Free. Started the car up, and as soon as the oil pressure came up there's was no lifter noise, just the pod filter sucking in air :)
s13deviat
Postby s13deviat » Thu Sep 23, 2010 3:24 pm
Bonza! Cheers TCR, i am always a little sceptical with these additives, but it seems people have had not issues using this Nulon Lifter free stuff!
Sorry to hijack thread but any recommendations for oil... is Castrol 10w60 the right choice??
I will do an oil change AGAIN and add some Lifter Free :)
SKYHI
Postby SKYHI » Thu Sep 23, 2010 3:36 pm
s13deviat wrote:Bonza! Cheers TCR, i am always a little sceptical with these additives, but it seems people have had not issues using this Nulon Lifter free stuff!
Depends on what you're using it for. Daily driver, weekend track warrior or dedicated track car?
Personally my car is pretty much a dedicated track car even though it's still registered, and I use the Castrol Edge 10W-60 for that extra bit of protection. I THINK the daily driver/weekend track guys use 10W-40.
s13deviat
Postby s13deviat » Thu Sep 23, 2010 7:08 pm
TCR wrote:Depends on what you're using it for. Daily driver, weekend track warrior or dedicated track car?
I hit a case of the 'lazyies' and lack of funds so i just bought the Nulon stuff and put it in.......... IT WORKED!!!! She is quiet as a mouse again!! About 2-3 secs and it was goneski!!
See how it holds up!!
Thanks for help :mrgreen:
Now onto next issue to fix.... this one is a pain... replacing wheel stud/bolt... fark me could Mazda make it any harder to get em out of the hub....... SHEET :evil: :!:
