No acceleration: Symptom of incorrect timing belt change?
jerrah
Postby jerrah » Wed Sep 15, 2010 6:36 pm
I changed my timing belt last weekend. It started up and idled ok but I hadn't dríven it.
On trying this afternoon the car has NO acceleration. I only took it up the street a little then back home again.
Sound like symptom of a timing belt job gone wrong? :(
1991 MX5
JBT
Re: No acceleration: Symptom of incorrect timing belt change
Postby JBT » Wed Sep 15, 2010 7:51 pm
It's quite possible that you have the cam timing incorrectly set. Running smoothly but lacking power/feeling dead is a general indication of retarded cam timing. It is not that hard to get it wrong by a tooth or two.
mattah
Postby mattah » Wed Sep 15, 2010 9:32 pm
I put my belt on wrongly the first time I did the change. Then I found a great pic on the net (linked below).
viewtopic.php?f=29&t=40436&p=525191#p525191
jerrah
Postby jerrah » Thu Sep 16, 2010 12:09 am
Thanks for the picture. Those timing marks though don't appear to match the marks on the back plate? If that runs great, but I'm still feeling a bit lost. I think I'll have to have a good look around before the weekend.
1991 MX5
mattah
Postby mattah » Thu Sep 16, 2010 12:45 am
jerrah wrote:Thanks for the picture. Those timing marks though don't appear to match the marks on the back plate? If that runs great, but I'm still feeling a bit lost. I think I'll have to have a good look around before the weekend.
I think it's just the angle of the photo. If you look at the bottom of the teeth with the mark, it lines up perfectly with the marks on the backing plate. My car looked exactly like that when it was finished, and ran great.
