Re: Recommended shop for diff centre swap in WA?
Posted: Mon Sep 06, 2010 5:31 pm
by sliq
i'd say its pretty hard to DIY if its the centre. you need the write tools to marry up the crown and pinion.
unless you're a mechanic by nature its something i wouldn't attempt on my own
Posted: Thu Sep 09, 2010 11:17 pm
by garbev
If you live anywhere near the hills I can give you the number of the guy who fitted mine and did an excellent job and a lot cheaper than I expected. he does quite a lot of work for the rally fraternity.
Posted: Fri Sep 10, 2010 12:24 pm
by Okibi
I used a diff specialist on O'conner, I haven't broken it yet so perhaps they did a good job.
Posted: Mon Sep 13, 2010 7:40 pm
by marcusus
Steve Lee did my Cusco diff install, and all up including a service it was $500ish. Hope that gives you the ball park figure you're after.
Posted: Thu Sep 16, 2010 11:02 pm
by tinsfci
For the speedo drive grab the drĂven gear out of an NA6 box, as they are 4.3 stock. I did that when I swapped to a 4.3 torsen.
