I tried the search function and only found info about the weight of each.
What is the diameter of each in mm please?
What is the extact weight in kg please?
Thanks in advance.
Ryan
Difference between NA6 and NA8 Flywheels
- Vehicle: Non MX-5
- Vehicle: 10AE
Re: Difference between NA6 and NA8 Flywheels
1.6 89-93 17.5lbs 200mm approx 7.9kg
1.8 94-05 22.5lbs 220mm approx 10.2kg
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
They look very different. And you will have to adjust the pedal for it to work. I have both the 1.6 and the 1.8 lightened flywheels. The 1.6 was about 5.9 kg's and the 1.8 was about 7.2kg's and with the bigger diameter it feels a lot heavier when driving than the 1.6. But i prefer it with the turbo on. Keeps you in your seat in 3rd to 4th gearchages.
