Removing coolant outlet at front of engine.
jerrah
Postby jerrah » Sun Aug 29, 2010 10:07 am
I'm working through a coolant reroute. I'm at the stage where I want to remove the outlet on the front of my B6. I just wanted to confirm something before I proceed any further:
Do I need to remove the cam belt to remove the outlet?
If so I might wait until I've got a new water pump and cam belt handy and do the lot in one go.
1991 MX5
Re: Removing coolant outlet at front of engine.
Postby 93_Clubman » Sun Aug 29, 2010 1:39 pm
yes according to the manual as, at least on the na8, the black plate blocks access to the housing bolts, & cam wheels need to come off to remove the plate.
jerrah
Postby jerrah » Sun Aug 29, 2010 3:40 pm
Hmm... Sounds like more hassle than I was expecting.
Now I have to toss up whether to do the timing belt/water pump now or just refit the existing items.
Repco want $300+ for the timing belt kit and $140 for the water pump which seems quite excessive for a $800 motor.
1991 MX5
Postby 93_Clubman » Sun Aug 29, 2010 4:15 pm
US$140 shipped to Aust BP kit:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 2089wt_941
here's some comment: viewtopic.php?f=29&t=43112
a few forumites have got stuff from CNS, but I've not heard feedback one way or the other, but as you say on an $800 motor, it would cost you that again if you weren't doing it yourself!
Fatty
Postby Fatty » Sun Aug 29, 2010 7:29 pm
couldn't you just leave the existing outlet in place, and put a cap on it? it wouldn't look as neat but it'd solve the problem and save you some money.
jerrah
Postby jerrah » Mon Aug 30, 2010 11:51 am
Yes a cap would work but I want to do it properly, encourage 100% flow in the correct direction and regain the space around the front of the engine.
Thanks for the tip on CNS, seems to be an OEM grade pump - hopefully the timing belt is of good quality. The whole B6 kit shipped (pump, belt and pulleys) was less than a pump alone purchased locally.
I'll take photos and update the forum on removing the water neck/ putting in the freeze plug etc etc.
1991 MX5
