Car stalls after long high speed drive
Captain Spank
Postby Captain Spank » Thu Aug 26, 2010 10:01 pm
Hi troops.
Have a fairly perplexing one. In short if I've been driving for a long time at high speed (eg. 100k for an hour). When I come to a near stop it almost stalls or in some cases dies and I have to restart the motor. If I'm driving around town it's fine, it's just the really long trips and coming down in speed quickly. I though it might be the gears but I recently had all the plates replaced and it's still the saem.
Any ideas or suggestions?
CS
Rice, rice baby. NA6 on the road to bling.
jerrah
Re: Car stalls after long high speed drive
Postby jerrah » Thu Aug 26, 2010 10:14 pm
Possibly throttle position sensor. I've seen a number of NA6 TPS's go bad.
1991 MX5
Postby 93_Clubman » Sat Aug 28, 2010 6:08 pm
Captain Spank
Postby Captain Spank » Tue Oct 12, 2010 9:55 am
Back again. Thought I'd give an update. Well the problems still persisting, but now with a small change.
Took it to the mech's and they ran a test on the TPS, the 02 sensor came back with an error, so they reset it and they read no further errors. Car also had a service and was incredibly low on oil (which I thought was odd as I'd topped it up not so long ago and being on a concrete driveway you'd think I'd see any leaks if it had some).
Anyway took it on a 250km trip around Vic (Shepparton, Rushworth, Euroa, Seymour, Broadford, Heathcote, Bendigo) the other day and for the 1st time after a long journey it didn't idle dip or stall out at a stop...but.
The following day back in Bendigo on a 'short' trip this time around town it happened again repeatedly. 1st things 1st, went straight to the mech's, got him to jump in and we took it for a small drive...of course the car had to work fine then didn't it? Aaaargh.
So we ran a tps check again and found no errors.
So my thought is would it be worth replacing the 02 sensor issue I've been reading a bit about on here for idle dip issues and should it also reduce my oil burning out so quick?
Postby bruce » Tue Oct 12, 2010 2:53 pm
Spark plug leads?
Captain Spank
Postby Captain Spank » Tue Oct 12, 2010 3:06 pm
Nope had new leads (and spark plugs) fitted a few weeks prior to the new clutch plates, and the issue had been happening prior to that change.
zossy1
Postby zossy1 » Thu Oct 14, 2010 5:57 am
Gas tank vacuum? Vapor lock?
Try removing your gas cap and see if it still happens.
Users browsing this forum: Google [Bot] and 4 guests
