Question re cam timing on NA 8
michael
Postby michael » Wed Aug 11, 2010 10:02 am
Hi All,
Can anyone tell me, with certainty, the number of degrees before bottom dead centre when the exhaust valve opens, for a 96 NA8 standard engine.
Thank you
Michael
broady
Re: Question re cam timing on NA 8
Postby broady » Wed Aug 11, 2010 11:44 am
no idea about before bottom DC but the spec is 10 degrees BTDC
人馬一体 NA8
6/5/2010
StanTheMan
Postby StanTheMan » Wed Aug 11, 2010 12:55 pm
are you refering to spark or cam timing broady?
and yes they are related but would be two different things altogether.
what he's asking has more to do with the opening duration of the cam profile and where it starts to move the valve open.. .....right?
broady
Postby broady » Wed Aug 11, 2010 3:26 pm
sh*t, you're right. Nevermind me. Just re-read it.
The info you're looking for is here:
http://solomiata.com/cams.html
人馬一体 NA8
6/5/2010
Postby manga_blue » Wed Aug 11, 2010 4:00 pm
Mazda specs for the 95 model NA8 are:
IN: open 5 BTDC, close 48 ABDC
OUT: open 56 B BDC. close 14 ATDC
michael
Postby michael » Wed Aug 11, 2010 4:09 pm
Thanks Magna_blue and fellas,
I was referring to the cam timing and when (degrees of rotation) the cam starts to open the exhaust valve and ideally when the exhaust valve then closes. That's what you have provided, right magna-blue ?
Regards
Michael
broady
Postby broady » Thu Aug 12, 2010 12:16 am
Yeah, and the specs provided by manga-blue are exactly the same as the ones on the solomiata site...
人馬一体 NA8
6/5/2010
michael
Postby michael » Thu Aug 12, 2010 9:13 am
Thanks broady,
Initially I missed the link in your earlier post.
Thanks for your help
Michael
