Woodruff Key Long nose crank
Dweezle
Postby Dweezle » Fri Jul 02, 2010 8:53 am
I am doing a timing belt, water pump seals etc change on my long nose Crank.
I ordered the key and crank bolt from MAZDA and they arrived yesterday.
The key physically looks different and is a different length to the one i took out.
I brought this up with them, but all they would say is "Its the correct part for that Vin number". :roll:
I just want to make sure, even the bolt looks a lil different.
Perhaps MAZDA changed the design a litle bit?
The Key just worries me becuase it is shorter and doesnt have anywhere near as big a wedge at one end.
Hope this can be cleared up.
Thanks in advance!!
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Re: Woodruff Key Long nose crank
Postby 93_Clubman » Fri Jul 02, 2010 1:01 pm
this might help: http://www.miata.net/garage/crankshaft.html
& this might also be useful: viewtopic.php?f=29&t=38766
Dweezle
Postby Dweezle » Fri Jul 02, 2010 1:37 pm
93_Clubman wrote:this might help: http://www.miata.net/garage/crankshaft.html
Thanks Clubman. :D
yeah, i still think they have given me the wrong Key.
The keyway on my crank has the inverted wedge shape at the end to match the key i took out.. DUH!!
I am now worried the bolt they gave me is the wrong one also.
I will measure it when i get home, and compare to the link you sent.
Just really annoying that MAZDA have seemingly given me the wrong part, i noticed, went back, and still was told its correct.
Bet they would do nothing if i installed the wrong key, had crank failure and asked to be reimbursed. :evil:
GRRRRRR!!
Jeremy Clarkson
StanTheMan
Postby StanTheMan » Fri Jul 02, 2010 1:53 pm
keep in mind it may be the right part for the vin No. but our cars are getting on.
I'd check if there wasn't an engine swap at one stage or another.
Then again....i once was accused of not telling them that i had a 1.6 when I ordered a aircon belt for a 1989 Mazda MX5 :roll:
Postby bruce » Fri Jul 02, 2010 1:53 pm
It looks totally wrong.
Has your car had a difft engine put in? (Thus it does not match description on Mazdas computers).
Dweezle
Postby Dweezle » Fri Jul 02, 2010 2:01 pm
My car is a MALIBU Gold.
91 model, and to the best of my knowledge.. "i am a NOOB to the GOLD.. HAHA".. They all came with the 8 slot, Long nosed Crank. Which mine has.
The engine number matches the engine in the car also.
So i am assuming it is the original engine.
I might drop into MAZDA again on the way home and try and talk to someone else that will hopefully be more usefull.
I physically showed the guy the 2 keys, he looked and went, "Correct part for correct vin" like some sort of robot. :x
Better try and make sure the bolt is correct also.
Does anyone know the part number of the long nose crank Key?
Jeremy Clarkson
Russellb
RIP Nov 2014
Postby Russellb » Fri Jul 02, 2010 2:36 pm
small nose
bolt B630 11 406C
key B630 11 310
pulley B366 11 321A
big nose
bolt B3C7 11 406
key B3C7 11 317
pulley B3C7 11 321
My ClubmanRebuild
MX5 SE Rally car is HERE :)
Dweezle
Postby Dweezle » Fri Jul 02, 2010 3:25 pm
Thanks Russel.
Mazda are stumped also.
That's the part number they gave me.
But the key is different.
There is also the same part number with a "c" at the end. So there ordering that in.
Mazda also tried to tell me that the crank design has never changed.. That's worrying!!!!
Jeremy Clarkson
Dweezle
Postby Dweezle » Fri Jul 02, 2010 4:25 pm
A little more Internet scrounging and I have come across this.
http://forum.miata.net/vb/archive/index ... 81188.html
Seems Mazda has changed there parts so all 1.6 keys are the same.
There is no wedge section anymore. It stops just before it.
Apparently it should be fine?
Kinda worrying but I suppose it's just an aligning tool? As long as it's a new bolt up to correct torque and the key slots in right it should be fine??
Please correct me if I'm wrong.
I might just reuse my old key.
Jeremy Clarkson
StanTheMan
Postby StanTheMan » Fri Jul 02, 2010 5:39 pm
Dweezle wrote:Mazda also tried to tell me that the crank design has never changed.. That's worrying!!!!
Don't take that too seriously. They are obviously talking out of thiere rectum but remember they are only workers. what would they know about the desingn process about any car unless they are enthusiast like yourself.
they need to know about every Mazda ever made not just a 1990's mx5. There is far too much other relevant info they need to keep in thier head.
Dweezle
Postby Dweezle » Fri Jul 02, 2010 5:55 pm
Oh yeah.. I completely understand.
Just was very annoying being told I was wrong, and Having 2 of them trying to inform me that!!
Thanks to all though for your help..
Hopefully I can finish this off this weekend !!! Yay
On a second note, I scored the last ever Malibu gold touch up paint hahA
Jeremy Clarkson
Old Dude
Postby Old Dude » Wed Nov 24, 2010 7:38 pm
I once had an "EXPERT" at Bunnings repeatedly tell me that a phillips head and a Pozi drive screwdriver bit were the same, until I showed him the difference. So don't trust what a spare parts guy tells you about a part, they might know what the right part number is, but know Jack sh*t, if it actually is the right part.
Dale 8)
MX 5 2001 Grace Green
NB8B
