I took my SP to Mania last Wednesday for its regular service and for David (Raddatz) to source an annoying intermittent metal ticking noise.
David found the noise was caused by a cracked PPF. Apparently for hi-powered MX5, it can happen. Not that I call my SP over-powered. It's only got stock boost (8psi). Nonetheless, the crack was along one of the four bolts that hold the PPF into the gearbox (at one end) and the diff (at the other). And needless to say, the whole thing was replaced.
For those not familiar with the PPF (Power Plant Frame), its the frame that directly connects the gearbox to the diff and it's made out of light aluminium. The engineers' thinking behind this is for an instant response when the floor is planted. Keeping the distance between the gearbox and diff constant, elimating lag on the drive shaft - so I've read from the MX-5 book.
I recommend you get your PPF checked next time your car is in for service (specially if you've turboed or supercharged it).
PPF
