i was driving to manly today and in traffic the clutch pedal suddently went to the floor and smoke came out. the car was not drivable after that. it did not make any noises and gave no indication prior that anything was wrong at all.
i am thinking that the clutch line suddenly gave out and there was no line pressure to disengage the clutch. the smoke i am thinking was the fluid coming out a hole in the line.
as anyone ever had this problem before?
any ideas if that is what it is (i really hope its that!!) or what it could be?
i parked it in a side street and will get it towed to somewhere tomorrow.
on that note does anyone know a good clutch place near mosman in nsw?
clutch problem - suddenly not working
- 16bit
- Old Dude
Re: clutch problem - suddenly not working
Sounds like either that or the slave cylinder crapped it self, either way the fluid reservoir will be low on fluid.
Sorry cant help with a good clutch place
Dale
Dale
MX 5 2001 Grace Green
NB8B
NB8B
- JBT
Possible cheap "get it to the repair place" fix if all the fluid has gone: get a small bottle of brake fluid, top up the clutch master and see if you can get pressure up again. You may need to get someone to check that a flexible line or union hasn't broken.
This may save on towing costs and get you mobile again.
- 16bit
is any of those things a box out jobby?
thanks for the replies!
turns out there is a midas 2 blocks up the main road.
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Both are easy jobs to do. No need for the gearbox to come out for the slave or master cylinders.
- Vehicle: NB Roadster
if its your slave cylinder repco stocks a repair kit for $15 if your the diy type pretty simple job only takes about 20 minutes or so
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
- 16bit
turns out the hard line failed. not sure if that is the entire problem but its the reason for the loss of hydrolic pressure.
Clutch slave failure is pretty common on the MX-5 any photos of the failed hardline? Was something rubbing on it?
- Quicksilver
If you haven't already got it repaired, give Danny a call at MX5Plus. They have a modification for the clutch pipe which is shorter and neater. I put one in last year when I had the same problem (also on a NB8A).
Actually, I replaced the slave cylinder first, then the clutch failed again two weeks later with a small tear in the clutch hard pipe. It may have been the real problem in the first place.
クイクシルバ
- 16bit
damn, part already ordered.
oh well.
i had a pretty large shunt with a bit of lifted road on my way down that could have caused it to crack somehow. that happen in coffs harbour though so might have taken a while to finally crack all the way through.
oh well.
Users browsing this forum: No registered users and 130 guests
